Umbau vom Fahrwerk....
Beitragvon Evo-Levo » 1. Feb 2007, 13:52
Hi Bertin2002
Habe leider nur ein Foto von Voren was zu gebrauchen wäre
Evo-Levo
Beitragvon JM Motorsport » 22. Sep 2009, 23:11
Hallo Evo-Levo i have the same problem as you with H&R springs, i too have the Nordschleife kit with 320 and 220 springs. Do you have the new part number for the springs? Did H&R replace both your front and rear springs?
On my car it looks ok on the rear axle but on the front its 7cm between arch and wheel, see picture below
- Mikael Lindqvist
JM Motorsport
Beitragvon Evo-Levo » 26. Sep 2009, 12:10
Hi
I sent only the front springs back ... and i send a picture to H&R from the car. 3 Days later they send me new springs for my car. Also i change the domlager ( ididnt know in english ) They are difrent to evo, may be 8 mm lover.
I think you have the springs from a 2,5 16v in the front. The same problem have we at ower white 2,5 16v. The car has now the evo1 body kit and it looks like your car in the front or like my bevor... For the white car we have cut the kit in the front and fit it lower then like original evo.
The part number was the same they tolt me that the kilo pund from the springs was wrong...
greeting
Evo-Levo
Beitragvon JM Motorsport » 26. Sep 2009, 17:18
Ok, thank you. I will contact H&R to get the correct springs for the front axle.
- Mikael Lindqvist
JM Motorsport
