Re: My Project
Verfasst: 24. Jan 2011, 17:08
Gorilla hat geschrieben:Hi,
Has anybody sourced the ''Plugs''
that fit these Polo 'COP 'to make
up a small wiring harness/loom ?
or,
Are they Main Dealer only ?
Many thanks,
Regards,
Gorilla.
You can either source loom from junkyard or buy at main dealers pins and connectors separately
and than produce your own wiring loom, also at VW they are to be sourced so called "repair wires"
and they are all yellow - it is a wire in needed diameter and on the other part is crimped a pin of
right type and size which one can later just insert in a corresponding connector.
I know that as we in family own a bunch of VWs
Here is an example how all this looks when ordered at main dealers with some prices attached:
watertight connectors vw (some of) and rep. wires
