EVO 1
EVO 1
Beitragvon Gorilla » 21. Dez 2010, 12:51
I am after some Evo 1 information please.
Is the EVO 1 Head, exactly the same Casting
as the 2.5 16v 'Coscast' Head please ?
Or, are all the EVO Heads Mercedes own Head Casting ?
Is the Oil pump on the EVO 1 Chain driven as
the Evo 2 please ?
As the EVO 1 has a Duplex Timing Chain I am not sure how ?
Evo II is single Cam chain.
Are the EVO 1 Con Rods [154mm] long, Forged or Cast ?
Is anybody running 11.5.1 Compression Pistions
in there EVO 1 Engine please ?
Many thanks,
Reagrds,
Gorilla.
Gorilla
Autos: Mercedes 190 16v
Re: EVO 1
Beitragvon JM Motorsport » 21. Dez 2010, 12:56
This is what i got from head, rest i need to check the workshop manual
not same casting as 2.5-16v
oil pump is not chain driven on evo 1
single cam chain
- Mikael Lindqvist
JM Motorsport
Re: EVO 1
Beitragvon Nagilum » 21. Dez 2010, 13:09
While the bore differes, the Heads are not exactly the same.
Evo1 still uses duplex-chain, just Evo2 has a single-chain again.
AFAIK most people driving STB are driving a C/R of 11.5+ (I think up to 13.0).
Re: EVO 1
Beitragvon Gorilla » 21. Dez 2010, 14:00
Mikael- many thanks for the info,
so just the Evo 2 is chain driven
oil pump, which given the space
on the Crank makes sense.
Nagi- thanks also, I know the 2.516v
will go to 96.5mm bore and that the
bore Diam on the Evo 1/11 starts at
97.3, but there is no water ways
between the bores on the Evo blocks.
Hence the 'centre to centre' on the bores
must be very similar on 2.516v and Evo ?
I would go 12.1 compression but much higher
then issues start to evolve unless you can
be sure of 99 ron Pump fuel.
Does the Evo 1 head have the larger stud
spacings for the Headers as well ?
Many thanks,
Regards,
The Gorilla.
Gorilla
Re: EVO 1
Beitragvon Gorilla » 3. Jan 2011, 15:47
Evo 1 std Pistons 97.3 bore @ 9-7-1 compression
Rod is 154mm with 51.7 Big end and 22mm Small end
Does anybody know the Piston Deck height please ?
''Das Kompressionshore mit Evo 1 Kolben bitte ?''
Evo 2 std Pistons 97.3 bore @ 10-5-1 compression
Does anybody know the Piston Deck Height please?
''Das Kompressionshore mit Evo 2 Kolben bitte ?''
Many thanks,
Regards,
Gorilla.
Gorilla
Re: EVO 1
Beitragvon 16vau » 4. Jan 2011, 19:03
some pics from original Evo 1 pistons
Gruß Norbert
Re: EVO 1
Beitragvon Gorilla » 4. Jan 2011, 19:46
16vau- Danke fur das pics von Evo 1 Kolben.
Do you have any more pics with the measurements please ?
I still require some of the measurement information on the pistons.
Many thanks,
Regards,
Gorilla.
Gorilla
Re: EVO 1
Beitragvon 16vau » 4. Jan 2011, 22:30
Bitteschön,
war mal fleissig und hab eine schöne 8) Zeichnung gemacht
Gruß Norbert
Re: EVO 1
Beitragvon JM Motorsport » 4. Jan 2011, 23:12
Evo 1 pistons
total piston height: 59.9
from centre of rod to top of piston: 32.9
Dish diameter 84mm
weight 455g
Evo 2 pistons
Dish diameter 76mm
Dish depth 2.4
- Mikael Lindqvist
JM Motorsport
Re: EVO 1
Beitragvon JM Motorsport » 4. Jan 2011, 23:13
Norbert war ein bisschen schneller :-D
- Mikael Lindqvist
JM Motorsport
Re: EVO 1
Beitragvon Gorilla » 4. Jan 2011, 23:36
16vau & Mikael- das ist super, bitte.
Vielen Danke,
Gorilla.
Gorilla
Mitglieder in diesem Forum: Google [Bot] und 8 Gäste
