From Ke jetronic to Efi
Beitragvon monkfish » 9. Nov 2011, 11:26
I guess some of you have gone to Efi, and i need advices.
First i would like to know wich type of injector i need to buy (Ev1 ? Ev6?)
Then could you show me some pictures of your trigger wheels, it would be easy to install it between the damper and the crank shaft pulley but i would have to offset the others pulleys as well.
I would like to see your throttle position sensor and how it could be installed on the stock throttle body.
My aim is not specially performance, but reliability and perfect control over fuel mixture and ignition, and if i can grab some HP as well all would be fine.
monkfish
Autos: 190 E 2.5-16
Re: From Ke jetronic to Efi
Beitragvon qp230 » 9. Nov 2011, 16:44
viewtopic.php?f=4&t=3584&hilit=trigger+wheel
:arrow: mein efi umbau 2.6 l-8v-36-1 trigger wheel.
qp230
Autos: c124
Beitragvon monkfish » 9. Nov 2011, 21:58
Danke
That's quite what i was thinking, except that the damper pulley was machined.
monkfish
Autos: 190 E 2.5-16
Beitragvon qp230 » 9. Nov 2011, 22:33
picture two
was machined
sorry my english is not so good :wink:
http://190rev.net/forums/showthread.php?t=38643
qp230
Autos: c124
Beitragvon monkfish » 20. Nov 2011, 12:34
Nobody else?
monkfish
Autos: 190 E 2.5-16
Beitragvon meisterjäger » 20. Nov 2011, 14:59
you have to machine the damper, and so you can place the wheel betwen the damper and the pully.
wich kind of management do you want to use, differnt managemants have different plugs, and so you have to chose your injektors.
Beitragvon monkfish » 20. Nov 2011, 20:57
I was thinking:
Hall sensor for engine speed sensor ====> OK i saw the pictures, it's the most clever setting according me.
Stock throttle body so i was wondering how to adapt a throttle potentiometer and wich one ?
Stock air box+Air Temp sensor ====> No problem
2 Map sensors ( the second for barometric correction) =====> No problem
Saab fuel rail =====> Ok but what is the best setting for fuel injector, wich ones, are there some injector that direct fit???
EDIS ignition system (after the fuel system will be ok)
My idea is mainly to
1/ Achieve better fuel economy
2/ Reliability
3/ A little bit more power.
4/ Remove Ke jetronic system and sell the parts to pay some of the EFI system.
I was thinking to use Megasquirt EFI, as it seems to be relativly cheap and efficient.
monkfish
Autos: 190 E 2.5-16
Beitragvon meisterjäger » 20. Nov 2011, 21:13
it´s no hall sensor, it´s an inductive sensor!
an hall sensor is like the thing in an vw carburrator, it needs 4 pins. you don´t get a hall sensor to fir it on a triggerwheel.
at second, i don´t nkow many about the megasquirt, at pther managements you kan use any trottle position poti, an you have the option to learn it.
you also need some adapters to fit the injektors, because the holes in the manyfold are to big to fit them.
sorry but my tecnikal english is not so good, but i´m, learnig by doing.
Beitragvon monkfish » 20. Nov 2011, 21:39
http://www.microsquirt.info/uswiring.htm
Here they say VR sensor or Hall Sensor, anyway both should be ok.
Concerning the fuel injector adapters, where can i find a set?
monkfish
Autos: 190 E 2.5-16
Beitragvon monkfish » 26. Nov 2011, 16:10
If someone could tell me where to buy injectors adapters, it would be great.
monkfish
Autos: 190 E 2.5-16
Beitragvon qp230 » 26. Nov 2011, 17:01
qp230
Autos: c124
