Projekt 2.5-16v,
Beitragvon JM Motorsport » 10. Okt 2009, 20:19
I havent done much in the last couple of days. Started today to matte down all plastic parts before painting. Not much to show really.
But i picked up a brand new ignition coil from a Volvo, used for example on the T5-R. Both Johan and "Racing" uses the same coil, and
i also found out, that also Henrik uses them in one of his old DTM Evos. I dont have the exact spec, but they give on hell of a spark.
I bought mine from the local Volvo dealer, costs around £90.
Next week we will probably try make some progress with the VEMS install.
- Mikael Lindqvist
JM Motorsport
Beitragvon Beavis » 11. Okt 2009, 10:06
Hi Mikael,
at first: Very nice project!! I really like reading this.
One question, how do your 8x18 wheels fit into the front and rear wheelhouse? Have you done any modification to them?
greets beavis
Beavis
Beitragvon JM Motorsport » 11. Okt 2009, 11:55
After converting to EVO 1 they fit both front and rear.
- Mikael Lindqvist
JM Motorsport
Beitragvon Beavis » 11. Okt 2009, 22:10
so you've changed the inner wheelhouse also?
Beavis
Beitragvon JM Motorsport » 11. Okt 2009, 22:17
Hello, no, i have retained the normal 16v inner arches. With the 16v arches, it rubbed on the back and front, but only on the outer wheel arch. On the inside it was not a problem at all.
i have 225/40 tyres now, perhaps with 225/35 or perhaps 215/40 you will be on the safe side?
- Mikael Lindqvist
JM Motorsport
Beitragvon Beavis » 12. Okt 2009, 16:18
ok thx, for the info. i also thougt of 225/40 , 'cause i can only find semislicks in that size.
ciao
Beavis
Beavis
Beitragvon JM Motorsport » 12. Okt 2009, 17:33
yes i know, there just not available in any smaller dimensions as semi-slicks. Cant you move down to 17"?
- Mikael Lindqvist
JM Motorsport
Beitragvon Beavis » 12. Okt 2009, 21:37
well, i think i could...could be 215/45/17 or 235/40/17...
i have to get some wheels in 17" an 18" from friends of mine, just to put them on and see how it looks..
Beavis
Beitragvon JM Motorsport » 12. Okt 2009, 22:01
i will use ATS DTC Superlight in 17x7.5" for semi-slicks, havent decided on tyre size, yet. But i will stick with Toyo R888 again
- Mikael Lindqvist
JM Motorsport
Beitragvon LUDE » 12. Okt 2009, 22:07
Den werde ich mir kaufen, aber eben in 17"
VENTUS RS-2 Z212 225/40 ZR18 92Y XL 4PR
Beitragvon Beavis » 12. Okt 2009, 22:49
yes ATS has some great wheels in stock! the DTC Superlight looks good too.
i thougt of OZ Suprtourismo GT...but i'm still in searching process :)
and yes, i want to get the toyo also...we'll see what happens... :D
@Lude: ist das nen "normaler" straßenreifen? den kannte ich noch gar nicht, gibt's den schon länger??
Beavis
Beitragvon ausmNorden » 15. Okt 2009, 22:00
@ Beavis: ich fahre zur Zeit Supertourismo GT in 8Jx17, 215/45 und 235/45 auf meinem 16v...
der Look ist echt klasse... kann leider keine aktuellen Bilder liefern, habe heute auf Winterreifen umgestellt...
MfG Stephan
ausmNorden
Beitragvon Beavis » 15. Okt 2009, 22:05
hallo nordlicher, in silber oder schwarz?schade, daß du keine fotos hast... :(
Beavis
Beitragvon ausmNorden » 16. Okt 2009, 19:49
sind in Silber... wenn ich den Wagen morgen wieder auf der Bühne habe, steck ich die noch mal eben rauf, wenn ich dran denke. Ich persönlich würde aber gern den Satz in Schwarz haben... hast vielleicht interesse an den Silbernen? sind vom vorbesitzer leider nicht so ganz gut behandelt worden, was kratzer angeht, aber da kann man ja drüber reden!
MfG Stephan
ausmNorden
Beitragvon JM Motorsport » 18. Okt 2009, 18:26
Started yesterday with the EFI conversion, my intention was to do a write up, but due to the amount of wires compared to both Johans car we didnt not take that much pictures, time just ran away.
Here are few ones from today, we are about 50% ready i would say.
Modifed to give a signal to the trigger. Might not look like the neatest
solution but it works good, same as Racing using
Fuse box remove, to sort out any unnecessary wires
Hmm, now where did these go?
Leftovers
Passenger footwell, pullinge the wireing through for the VEMS box
This what have been removed from the old harness. I reckon
its at least 3kg
And finally, all though its a crappy pictures, this is a replica of
the sticker (only on paper) used on the DTM car. All cars in the
DTM had to pass the inspection from the marshals, after the
inspection this sticker was fitted on the inside of the rear door
window, on the outside the different stickers from the marshals
inspection was applied.
- Mikael Lindqvist
JM Motorsport
Beitragvon Beavis » 18. Okt 2009, 19:18
@ausNorden: PN
Beavis
Beitragvon JM Motorsport » 25. Okt 2009, 21:43
VEMS install continued yesterday, we are almost there know. Didnt have any time today since we were busy getting Johans car on the dyno. But hopefully next weekend it will be ready.
Modifed water temp sender from BMW. With new threads it fits in the stock outtake. There is a Mercedes sender you could use, it will screw right in with not modifications needed,
but i wasnt aware of that, so i bought this one. But it works.
Running wires for the injectors, as the car wont pass MOT in Sweden using ITBs, we need to make sure the wiring fits both stock manifold and ITBs, as we will exchange the manifold for ITBs once a year after MOT.
Nylon wire hose, im not sure what its called in english, but its heat resistant and looks very neat.
Volvo (Bosch) 850 ignition coil, fits using the old bolts
Thermostat housing blanking bolts, BMW water sender and stock mercedes sender with new wiring to the VEMS box.
- Mikael Lindqvist
JM Motorsport
Beitragvon Nagilum » 26. Okt 2009, 00:34
Looks really nice...
I'm waiting for more... ;)
Beitragvon JM Motorsport » 1. Nov 2009, 16:19
Small update, VEMS install continues. Just realized that it takes a lot of time doing the wiring. Injector wiring is done, just need to found those rubber thingies that
goes over the injector connector. Not necessary since the connectors are scald but it looks smarter. There are still a few wires that need to be sorted before i can
the interior and under bonnet bits back.
Opened up the alternator and found this :blink:
Found this one on Ebay the other week, been looking for one for 3 years know but now i finally found one.
Here in van Ommens Evo 2 from 1992.
- Mikael Lindqvist
JM Motorsport
Beitragvon db16v » 1. Nov 2009, 23:16
Hey,
Sieht sehr sauber aus.
Bin schon gespannt, auf das endergebnis.
