Projekt 2.5-16v,
Beitragvon JM Motorsport » 10. Jan 2010, 17:08
Thank you.
Things that need to be sorted.
- Put the exhaust back up
- Connect the new lines for the vacuum system, from VEMS box to MAP.
- Put the interior bits back in,
- Threads on my oil cooler were bad so i need get that sorted, then i can put it back in
- Order new tyres
- Order new front brake discs, put my Brembos calipers on
- Various small parts from Mercedes as ignition wires, distributor cap, repair kit for gear linkage and of course a battery
- Put all fluids back in
- Final checkup that all sensors are working with VEMS box
Two more weekends and it should all be done.
Here are few pics from the last couple of days.
Found my old Becker radio that came with the car and decided to put it back in,
This is for the oil filter adapter install, the threaded part was a bit to long so it fouled the oil temp and pressure sensor, so we needed to cut them down
to the correct length,
Finished result, sensors and hose connectors screwed back in.
Adapter plate bolted to the block, this plate is needed when you use ITBs, the original oil filter housing will hit the ITB manifold,
Soldering time, we finished the last part of the VEMS install, this is the wiring for the Trigger sensor,
Finished result, we used a high quality Hirschmann connector, just to make it more service friendly for example when you take the engine out. Just disconnect it, no need to remove
the Trigger sensor from the engine.
New alternator belt, i had AC before, but we took it out so we needed the shorter alternator belt.
Everything back in place except for the intake and battery.
- Mikael Lindqvist
JM Motorsport
Beitragvon Nagilum » 10. Jan 2010, 18:19
It looks really good.
Always nice to see your updates.
Beitragvon JM Motorsport » 23. Jan 2010, 18:10
New bushings for the front control arms. I had these made in Thailand, quality seems very good.
- Mikael Lindqvist
JM Motorsport
Beitragvon 16vau » 23. Jan 2010, 20:25
Gut ist was hart macht 8)
Schöne Arbeit
Gruß Norbert
Beitragvon JM Motorsport » 9. Feb 2010, 20:51
Been looking for a set of 7,5" Evo 2s for a long time now, cant find any used ones. But i came across a company called Alloy Wheels Direct in the UK, and i found a set of brand new Evo 2s in Titanium for £540, rather cheap i thought, Especially since Mercedes Germany says they aint available anymore.
Need to sort a set of Toyo R888 semi slicks now, in 215/45 I think. I now its not the lightest wheel out there, but i will have to do.
Looks rather small without any tyres.
Im getting a set of Speedline decals made,
And voila, almost like the real thing B)
- Mikael Lindqvist
JM Motorsport
Beitragvon Beavis » 9. Feb 2010, 21:25
hi mikael,
was ist denn mit deinen compomotive in 18" ?
Beavis
Beitragvon JM Motorsport » 9. Feb 2010, 23:27
Hallo, der Evo felgen is nur für den rennstrecke, mit Toyo R888 motorsportreifen.
- Mikael Lindqvist
JM Motorsport
Beitragvon JM Motorsport » 18. Feb 2010, 19:07
Sold my old manifold and bought Atecs, instead, matched to my cylinder head and 50mm DCOE Throttle bodies which i already got. I will
manfucature my own adapter plate between throttle bodies and carbon air box.
And a few carbon parts
- Mikael Lindqvist
JM Motorsport
Beitragvon AzzurroPower » 18. Feb 2010, 22:18
just perfect!
AzzurroPower
Beitragvon Henger » 18. Feb 2010, 22:48
Hallo Mikael,
dein Projekt nimmt immer mehr Gestalt an 8)
Was ich zu sehen bekomme, macht alles einen guten Eindruck, die Teile die du verwendest sind alle mit bedacht ausgewählt.
Dein Styling finde ich auch gut, was aber immer Geschmacksache ist.
Was ich bei deinem Projekt am besten finde, ist, das es ein individuelles Projekt ist und du fast alles selbst er und verarbeitest.
Bitte weiter so, wir sind alle auf das Endprodukt gespannt...vielleicht wäre Hockenheim ein guter Platz um den Wagen zu präsentieren :wink:
Nette Grüße
Beitragvon 190er-16V » 18. Feb 2010, 22:54
respect, nice work
regards
190er-16V
Beitragvon LUDE » 18. Feb 2010, 23:20
Nice Work and a nice Phone!
Beitragvon partyboy » 18. Feb 2010, 23:54
LUDE hat geschrieben:Nice Work and a nice Phone!
+1
Mfg, Nando.
partyboy
Beitragvon JM Motorsport » 21. Feb 2010, 18:27
Thank you very much everyone.
Frank, i whish i could be ready to the meet at Hockenheim, but i think it will be hard. Im having trouble finding someone that can do the Evo 1 conversion at the rear.
I was down in the garage today, and tried fitting my new intake from Atec. Im considering getting the adapter plate between the throttle bodies and airbox that Atec also sells, together with air trumpets from VGS, but it depends on how much it costs. I have thought about doing it myself, but i havent really got the time.
I probably also need to get a new hose for the cooler, it hits the airbox now, and i need to get the filter box so it lines up with the airbox, its not sitting correct now.
Here is the problem:
1. coolant hose is in the way,
2. The angle of the filter house is wrong, do i perhaps need to modify the
cooler or its position? Does anyone know?
- Mikael Lindqvist
JM Motorsport
Beitragvon 16vau » 21. Feb 2010, 20:35
Look here
mod the cooler position
gruß Norbert
Beitragvon Tising » 21. Feb 2010, 20:53
Wieviel muss man die wasserkühler versetzen? Und welche unterscheid zwischen die kleiner und grosse kühler?
Tising
Beitragvon 16vau » 21. Feb 2010, 21:00
müssten 6 cm nach rechts sein
- ich hab den kleinen Kühler am EVO 1
Gruß Norbert
Beitragvon JM Motorsport » 21. Feb 2010, 21:06
Thank you Norbert, i have the large cooler and it would be hard to move it 6 cm i think.
Patrick in this thread seem to have the large cooler but it doesnt look like he have moved the cooler, but has made custom coolant hose.
http://w201-16v.de/w201/viewtopic.php?t=527
Zuletzt geändert von JM Motorsport am 21. Feb 2010, 21:21, insgesamt 1-mal geändert.
- Mikael Lindqvist
JM Motorsport
Beitragvon Tising » 21. Feb 2010, 21:07
Ich auch an meinem EVOI. Haben Sie kühlungs probleme gehabt?
Tising
Beitragvon 16vau » 21. Feb 2010, 21:19
@tising
das Auto ist noch nicht fertig, ich habe noch keine Erfahrungswerte
@JM Motorsport
dann mußt du den Kühler soweit möglich anheben und befestigen
und den Kühlwasserschlauch leicht nach oben weg zum Motor verlegen
so sieht es bei Patrick auf dem Foto aus
