Turbo cosworth project begins from Finland
Re: Turbo cosworth project begins from Finland
Beitragvon EVO3 clone » 15. Mär 2018, 16:29
Yes! the old king is back.
you are right about the sustainability of this part..
w124 big rear axle swap is not difficult, Here are a few photos of the conversation.
:danke
yes, orange sticker = oil friction reducer
EVO3 clone
Autos: Mercedes benz W201 2.3 16V
Beitragvon Steffen102992 » 15. Mär 2018, 23:56
Good news with this friction reducer! I missed it!
What's the part number of it?
Did you swapped the "ASD ring cylinders" from 201 Diff to the 124 Diff?
Because there is a difference in the connection/location of the short hydraulic line...
Actually I rebuild a rear axle too.... I thought "do your 16v something good and buy the 4 screws (which attaches the Diff to the Axle frame) new from MB...."
Bullshit... I was in shock.... MB wants 25€ Plus VAT for one screw! :spinnen:
So I took the old ones! :mrgreen:
MfG, Steffen!
Meine Autos:
-190E 2,5-16 Evo 1 Bj. 89
-S211 E220 T CDI Bj. 08
Steffen102992
Autos: W201, A124, S211
Beitragvon EVO3 clone » 16. Mär 2018, 19:02
i need to check this conversio whether it is 185mm or 210mm rear axle swap ..
stainless steel. downpipe 4 inches,
the next tube 3.5 inches and the end tube 3.0 inches
EVO3 clone
Beitragvon EVO3 clone » 22. Mär 2018, 20:25
VI-PEC v44 wiring harness and VW direct ignition coil.
EVO3 clone
Beitragvon Nagilum » 22. Mär 2018, 23:35
Didn't they overheat, when you put the cover back on - or will you just leave it open?
Beitragvon EVO3 clone » 23. Mär 2018, 21:26
3 years driving and cover is in place and works.
I'm hopeful and I hope the best ..
EVO3 clone
Beitragvon EVO3 clone » 31. Mär 2018, 20:20
shift shift repair, Dyno session.
EVO3 clone
Beitragvon EVO3 clone » 14. Nov 2019, 20:21
Radalle,com
Timeattack Alastaro 2019 :schalt
https://www.youtube.com/watch?v=_-MhkSD2I3o
EVO3 clone
Beitragvon Nagilum » 18. Nov 2019, 16:24
What's the result of the dyno session?
Beitragvon EVO3 clone » 19. Nov 2019, 19:58
The latest dyno session
-1.3 bar. 478 Hp / 610 Nm
Old dyno session
- 1.0 bar. 410 Hp / 510 Nm
https://www.youtube.com/watch?v=rCaYs2h4Ffc
EVO3 clone
Beitragvon jeandersson » 26. Nov 2019, 15:03
Hi
Really impressive work you have done there. The finish is awesome :Daumenhoch: What kind of coating have you used for the valve cover (and lots of other parts)?
//Johan
jeandersson
Bilder: 30
Autos: Mercedes 190e 2.3-16v
