Projekt 2.5-16v,
Beitragvon JM Motorsport » 2. Jun 2009, 14:12
I like the design, thats the only reason. I will not use these for track-days so weight is not that big issue. Will need to find something else to use on track.
- Mikael Lindqvist
JM Motorsport
Beitragvon JM Motorsport » 28. Jun 2009, 10:37
They arrived last friday:
- Mikael Lindqvist
JM Motorsport
Beitragvon Rouven036 » 28. Jun 2009, 11:49
verry nice rims!
Beitragvon JM Motorsport » 7. Aug 2009, 21:56
Gave my rocker cover and spark plug cover some attention today. I had removed the paint a while ago but today i sanded it and applied a few thin coats of grey primer, AMG cover was also painted satin black. Didnt have time to do the rocker cover.
I haven decided if i should sand it down or paint the bars and text with silver. Perhaps i should try to paint it using a fine brush, and then a few coats of matte clear laquer?
Original covers off an Evo 1 in 1990
Crappy phone pic of mine
- Mikael Lindqvist
JM Motorsport
Beitragvon JM Motorsport » 7. Aug 2009, 22:00
Making progress, most of the engine has been assembled now,
You can clearly see the ported exhaust ports
- Mikael Lindqvist
JM Motorsport
Beitragvon 16vau » 7. Aug 2009, 22:44
If you can paint like van Gogh, make it with the fine brush.
However, is a lot work, or you can varnish it maybe with a role?
Sand much easier goes
Afterwards paint a matte clear lacquer, otherwise get dirty metall very fast
Beitragvon JM Motorsport » 12. Aug 2009, 20:26
Recieved this from VEMS in Hungary today, well suprised of the quality of the harness, it actually comes in three parts, main harness, relay and fuse part, and injector parts, all parts are detachable. Makes it a lot easier when removing the engine. Notice the thick rubber grommet on the large part of the harness, will make a good tight seal through the firewall.
- Mikael Lindqvist
JM Motorsport
Beitragvon Henger » 12. Aug 2009, 22:04
Hi Mikael,
this parts looks like a good quality!
Hope we can see soon the end of your projekt :mrgreen:
Nette Grüße
Beitragvon JM Motorsport » 12. Aug 2009, 22:19
So do i Frank, next year Hockenheim, i promise!
- Mikael Lindqvist
JM Motorsport
Beitragvon Henger » 13. Aug 2009, 01:02
JM Motorsport hat geschrieben:So do i Frank, next year Hockenheim, i promise!
Es wäre echt super wenn wir uns nächstes Jahr in Hockenheim wiedersehen.
Besuch aus Schweden ist immer interessant 8)
Es ist eine Wiederholung des DTM Revivals geplant und es haben schon einige aus England, Belgien und anderen Ländern signalisiert, das sie dabei sein möchten........es werden viele Internationale Besucher/Teilnehmer erwartet :mrgreen: .
Ich finde dein Projekt bislang sehr gelungen, da sind viele Dinge dabei, die mir sehr gut gefallen.
Ich bin auch auf deinen EvoI Umbau mit den Body Kit Teilen von http://elbe.ee/index.php?page=mb-spetsiaalosad gespannt.
Bitte so weitermachen :thumbright:
Nette Grüße
Beitragvon JM Motorsport » 13. Aug 2009, 09:31
Thank you Frank,
- Mikael Lindqvist
JM Motorsport
Beitragvon JM Motorsport » 20. Aug 2009, 20:36
Small update, waiting for two big parcels late next week. Anyway ordered a set of Goodridge hoses from Ebay, very cheap £44.
Also picked up a water temp sensor from Bosch, there like £13 new. These are fitted to many BMWs but i think they are more expensive if you go to a BMW dealership instead of as i did go to a local auto parts store. The funny thing is that Bosch Motorsport also list this particular sensor on their webpage (http://www.bosch-motorsport.de/pdf/sens ... TC_M12.pdf).
- Mikael Lindqvist
JM Motorsport
Beitragvon partyboy » 23. Aug 2009, 13:18
This proyect is incredible, congratulations!!
Mfg, Nando.
partyboy
Beitragvon JM Motorsport » 1. Sep 2009, 13:25
thank you Nando
Johan have finished stripping the VEMS harness, before picture
And after, 26 wires removed
- Mikael Lindqvist
JM Motorsport
Beitragvon partyboy » 1. Sep 2009, 20:15
Thank you for the photos and the great work !!
Mfg, Nando.
partyboy
Beitragvon JM Motorsport » 5. Sep 2009, 18:45
alve cover and AMG spark plug finally done, satin black with a few layers of satin clear coat
Trial fitted covers and ITBS with manifold, bit worried that the carbon airbox might not clear the brake booster.
This ones from Atec in Germany copy of the early (up to 91) blanking plate for SLS used on the DTM cars
not so funny, previous owner managed to destroy the threads on the oil cooler, need to get this fixed
- Mikael Lindqvist
JM Motorsport
Beitragvon fisch007 » 5. Sep 2009, 20:39
very nice pictures,
W124 320CE zum Cruisen
W201 EvoII fürn Spaß
fisch007
Autos: W124 320CE zu Cruisen
Beitragvon Heinolution » 5. Sep 2009, 21:05
Hi, as an newby i can only say: good job!!
do you also replace the mainbrake calliper for an evo version? the diameter is larger. ( i think)
And did you put higher compression pistons in the engine?
And what cams are you using?
Sorry for al the questions, but i am really interrested.
Because going to do exact the same ,when i'am recovered from my back fracture. only with an 1984 16v version but with an 1989 2.5 16V donor
With an hagmann inlet manifold!!! so i'am also very interrested in the carbon airbox.!
Greetz Heino
Heinolution
Autos: 16V EFI LPG
Beitragvon JM Motorsport » 5. Sep 2009, 21:19
Hello Heino, i havent changed the brake booster for the EVO version, i will try with the stock 16v.
Piston are around 11.3 in compression, and con rods (pleuel) are forged from Volvo B230 Turbo engine.
Im looking forward seeing pictures from your own project, hope you recover soon from your back injury!
- Mikael Lindqvist
JM Motorsport
Beitragvon Rouven036 » 5. Sep 2009, 23:20
valve cover is pretty nice... like to have the same.
i m guessing also that you might face space issues with the airbox.
u might have to go for a smaller brake booster, reroute the brake line of front achsle circuit to the left side of the master cylinder and plug the right side. or you have to modify the airbox...
anyway, nice build, can't wait to see the next steps...
