Marceldeijkers Mercedes 190E 2.3 16v 1985
Beitragvon marceldeijkers » 13. Feb 2009, 20:37
Iam Marcel, iam 23 years old and i started with a W123 200 car from 1977, After drivin that car for 4 years i bought myself a 1983 190 !, And 1 year later i bought a 190E which i sold a few months back. When i buy a car i will strip it down, clean and fix the things and then rebuild it....
I finaly found myself a good base 190E, I got the car in France, and yes it the Version of france :) The car is from May 1985, just 9 days younger then myself! It got those options:
Dealer France, Monaco (531)
Interior fabric black+anthracite (071)
Paint
702 smoke silver metallic (с 01.01.1983)
Options
240 outside temperature indicator (с 01.03.1982)
260 elimination of model designation on rear lid (с 01.05.1968)
261 elimination of model designation V12 (с 01.11.1973)
410 electric sliding roof (с 01.03.1965 по 29.02.1988)
466 central locking system (с 01.04.1970 по 31.10.1993)
470 anti-lock braking system (abs) (с 01.06.1978 по 31.10.1993)
506 outside rear view mirror, left and right, heated (electrically adjustable on the right) (l.h.d.) (с 01.10.1983 по 31.03.1989)
outside rear view mirror, right, convex, taxi export version
543 sun visor with vanity mirror, illuminated, left and right (с 01.11.1978)
572 front seat, right, with seat height adjustment; l.h.d. (с 01.08.1975)
584 electric window lifters (front and rear doors) (с 01.04.1970)
electric window lifters, fourfold or sixfold
593 heat-insulating glass, all-around, heated rear window pane (single-sheet safety glass), band filter
green heat-insulating glass all round, heated rear window, single pane safety glass - tinted strip (с 01.01.1972)
600 headlamp wiper/washer (с 01.08.1971)
610 headlamps and fog lamps and additional bright light with amber lenses (с 01.11.1965 по 31.03.1994)
629 version for France (с 01.04.1964 по 29.02.1988)
630 ECE warning triangle (с 01.08.1980)
876 rear door contaCTS and lamp above rear window (с 01.07.1964 по 31.10.1993)
The only thing the old owner took of where the headlamp cleaning system.. , I already got myself a nice pair of Orange Hella blinkers! I only need the original rims on it...
At this moment i am stripping the car! 3 wheelcovers where perfect! and 1 on has some rust... I have to fix that.. but its all out of sight!
marceldeijkers
Beitragvon nfspeedy » 13. Feb 2009, 20:48
Very nice car!
How much kilometres has it?
realy nice condition - looks fantastic! :D
nfspeedy
Beitragvon marceldeijkers » 13. Feb 2009, 21:00
nfspeedy hat geschrieben:Very nice car!
At this moment around 191.xxxkm iam the 4th owener..
got all the maintaince papers from 2002 sinds 2009.. :)
I have seen some cars in the Netherlands, even one in Denmark... But the all had alot of rost.... This one has 1 spot on the right rear wing at the buttom... But that can be fixed without ever see it :)
marceldeijkers
Beitragvon nfspeedy » 13. Feb 2009, 21:16
congratulation to your new 16 Valver! :D
take care of it ;)
nfspeedy
Beitragvon marceldeijkers » 13. Feb 2009, 22:02
nfspeedy hat geschrieben:congratulation to your new 16 Valver! :D
take care of it ;)
Thank you ! :) What a great car! 2 times more power as my standard 190 which has 90 ;) I hope i can finish this car before the summer ends... i would love to go to Hockenheim! In holland you dont see alot of them....
marceldeijkers
Beitragvon nfspeedy » 13. Feb 2009, 22:07
Yes I'd like going to hockenheim too! :D
It will be nice to see you there! you and your 16ner
nfspeedy
Beitragvon marceldeijkers » 13. Feb 2009, 22:17
if everything is going as i plant... i can drive the car this summer... but the welding i need to do must me done... but the weather outside is to cold or snowing so i cant do it... in 2 weeks i got 1 week of, so if the weather is fine it will be done :)
marceldeijkers
Beitragvon nfspeedy » 13. Feb 2009, 22:21
What do you want to weld?
Whish you best weather for your doings ;)
nfspeedy
Beitragvon marceldeijkers » 13. Feb 2009, 22:25
the right hear wheel stroke,,, see pictures... the Wagenheber point where perfect :D
marceldeijkers
Beitragvon Henger » 13. Feb 2009, 22:25
Hallo Marcel,
willkommen bei uns im 16V Forum :D
Dein 2.3er sieht wirklich gut aus, ich hoffe der Wagen ist bald so, wie du ihn haben möchtest...und besuchst uns damit in Hockenheim 8)
Beste Grüße
Beitragvon marceldeijkers » 13. Feb 2009, 22:28
Just behind the rear bumper theres abit of rust... but not that big... i fix it and you will never see it :)
marceldeijkers
Beitragvon nfspeedy » 13. Feb 2009, 22:49
ah o.k. it is really not a big thing :D
nfspeedy
Beitragvon Heckantrieb » 14. Feb 2009, 14:17
Welcome, you have a nice car.. congratulation!!
Greetings
Tommy
Heckantrieb
Beitragvon JM Motorsport » 14. Feb 2009, 18:39
Very nice car, one of few 16vsold in Monaco!
- Mikael Lindqvist
JM Motorsport
Beitragvon marceldeijkers » 14. Feb 2009, 18:49
yes idd !!! i dont know how many france versions there are?? but i keep it in this state :)
marceldeijkers
Beitragvon marceldeijkers » 17. Mär 2009, 20:42
here`s an update... in 1 month i did all of those things :
Installed a new dashboard!
renewed some off the dashboard lights!
Installed Original MB 10cm speakers in the rear instead of 2 10cm pioneer crap.
Fixed the rear speaker grills with new fabric
fixed the rear left rust problem! weldet it.
Almost finished the rear right rust problem see pictures...
cleaned almost the entire bodykit and putted in Meguaris!
Painted my tacho unit.
Removed the front wings... no rust there!
also no rust at the wagenheber points!!!
marceldeijkers
Beitragvon Schöni » 17. Mär 2009, 21:06
Nice pictures!!
why did you paint the tacho unit???
have you pictures of the painted tacho??
best regards
Schöni
Beitragvon Rouven036 » 17. Mär 2009, 21:07
good job, well done!
Beitragvon Henger » 17. Mär 2009, 21:07
the car looks reak good under the wings, no rust 8)
Beitragvon marceldeijkers » 17. Mär 2009, 21:12
i Painted them because the where colored by the sun....
I also had to take it out to refit a new dash... so thats why :) I used Revell paint.
I want the car done before Hockenheim this year! :)
marceldeijkers
