Strange noise from underneath the car...
Beitragvon London-16V » 23. Nov 2007, 19:42
Hi guys,
Well this is a strange problem and one that NO ONE can solve it seems!
Recently at low revs i can hear a rattling noise fron underneath the car.
Some people said it was the exhaust so the front and middle section of the exhaust was changed and the all the heat sheilds.
The noise is still there. Its like a metallic rattling...up to 2,000RPM you can hear it a lot, but after that you cannot.
Please guys, do you have any idea what this is? Someone else told me thiis is normal!??
Thanks
Zak
London-16V
Beitragvon Nagilum » 23. Nov 2007, 20:50
That's definately not normal!
I also had such a problem. At my car it was the heat shield from the catalyst. I just removed it (and cut my finger on the f*cking sharp metal) and the noise was gone.
Maybe you should take a look from under the car (e.g. on a car lift) and try to hear where the noise comes from.
Beitragvon London-16V » 23. Nov 2007, 21:14
Hi Nagi,
My car has no cat. My feeling is the heatshield too. But they are all new! The noise is VERY annoying! Any other ideas please???
Thanks!
London-16V
Beitragvon Tising » 23. Nov 2007, 22:39
Put the car on a carlift, start the engine and locate it like that :oops:
Tising
Beitragvon Maki » 23. Nov 2007, 23:20
@London -do it the way Tising described it !
That's how i located a noise which came from underneath my car - btw it was a loose mounting from the exhaust ;-)
Beitragvon London-16V » 24. Nov 2007, 00:08
Hi Tising & Maki :-) Well thats what i told my mechanic to do, but he has not done it yet! Unfortunately British mechanics are not as efficient as German ones!
London-16V
Beitragvon Nagilum » 24. Nov 2007, 01:01
If other ppl are unable... just do it yourself. At least locating the problem is a thing you can do yourself for sure...
Beitragvon Henger » 24. Nov 2007, 02:07
Hi Zak,
this one is a specializer for noise.
Beitragvon London-16V » 24. Nov 2007, 02:12
Dear Henger,
Thankyou for taking the time to post that picture :-)
As you can see this part is new on my car...But the rattle is still there!
London-16V
Beitragvon Tising » 24. Nov 2007, 11:36
Hi
As the pictures show it´s all brand new. MUST have cost a bundle :shock: to change all off that, ai´.
I for one are a little impressed :oops:
"Keep the faith, Luke. And may the force be with you, my son." :lol: 8)
Cheers
Kim
Tising
Beitragvon Rouven036 » 24. Nov 2007, 15:00
hi london!
i watch to your picture and maybe i see the reason,check the clearance between the heatshield and the exhaust system.
below i marked it on you picture:
Rouven036
Autos: W201
Beitragvon Senna » 24. Nov 2007, 17:24
I think there where Rouven show it, can be really the place from where the noise comes.
And even if everything is new, can be that the parts don't fit good together.
In my opinion the noise might come from one of the heat shields, that is around the exhaust system from your car. So if you follow the advise from Tising you might find also the noise.
Greetings Senna
Senna
Beitragvon London-16V » 24. Nov 2007, 19:28
Hi Tising: I always try and do things the proper way! i do not like taking shortcuts at all. So i replaced the entire exhaust from Mercedes. Im not a fan of aftermarket exhausts! Well, in the UK the after market exhausts are pretty bad.
Hi Rouven036: I think you may have hit the nail on the head as they say! That is very well spotted! :-) I am going to get the car on a ramp and rev the engine to 2,000RPM and get the mechanic to look at that part!
Hi Senna: I agree with you even new parts do not fit well together. But a point to make is that this rattling noise was there before also! Thankyou Senna, im going to investigate this further :-)
Some random pics:
London-16V
Beitragvon db16v » 25. Nov 2007, 01:45
Sieht sehr gut aus dein Auto.
Ich hätte zufällig noch die Verkleidung links neben dem Kombiinstrument.
Wenn du es gebrauchen könntest. Ist neu und original Verpackt.
Beitragvon Nagilum » 25. Nov 2007, 15:28
Wow... your car looks realy nice!
I would eat from that car... ;)
Even the SLS-tank looks absolutely clean.
Interesting... they even changed the place of the battery and the fuses.
Mitglieder in diesem Forum: 0 Mitglieder und 43 Gäste
