lambdasonde
lambdasonde
Beitragvon TyskeBiler » 1. Apr 2013, 00:40
Hi Guys.
I'm from Denmark. therefore write in English.
I own a 2.5-16V with an engine code 102 990th. when I write this engine code on Mercedes EPC Program. it says that my car has 204 HP.
Mercedes says that my car is born without catalyst. but the car is imported from Germany to Denmark. which are retrofitted Catalyst car.
so my question is. why is there original catalyst and lambda sensor but a Unoriginal G-Cat unit `?
why is lambda sensor mounted on the car's engine control unit. and G-cat control sits all by itself
the law says in Denmark that we do not need Catalyst if the car is not born with it
I would like to remove the catalyst in my car
Regards AAron
TyskeBiler
Autos: w201-2.5-16v
Re: lambdasonde
Beitragvon Nagilum » 1. Apr 2013, 01:06
I've (re)imported my car from Denmark - and it also had 204 HP.
You just have to put back the original "RÜF"-Exhaust (without catalyst), remove the lambdasensor and change the "Abgleichsstecker" from KAT to RÜF.
There are 2 of these, IIRC one on the left front fender and one behind the battery/next to the KE-controller.
AFAIK these "Abgleichsstecker" are not available anymore by Mercedes. I don't know where I have left mine - I don't need them anymore.
Why someone changed from RÜF to KAT... you have to ask him, not us. ;)
In Germany you have to pay different taxes and that means some hundrets € per year.
Re: lambdasonde
Beitragvon TyskeBiler » 1. Apr 2013, 02:17
hmm ok
You do not know what number they should be on ...? the KE-controller.
I have removed the catalytic converter and lambda.
Regards Aaron
Nagilum hat geschrieben:I've (re)imported my car from Denmark - and it also had 204 HP.
TyskeBiler
Autos: w201-2.5-16v
Re: lambdasonde
Beitragvon Nagilum » 1. Apr 2013, 12:17
These Abgleichsstecker (~ comparison plugs) are round and have KAT on them (I think both). If you change them, IIRC one is labeled RÜF and the other ECE.
I don't know the partnumbers.
Re: lambdasonde
Beitragvon Henger » 1. Apr 2013, 13:41
Hallo
Abgleichstecker KE ohne Kat: 014 545 70 28
Abgleichstecker EZL ohne Kat: 015 545 27 28
Das sind die Teilenummern der Abgleichstecker für den Betrieb in RÜF.
Es gibt einige Threads im Forum dazu:
viewtopic.php?f=4&t=1421
viewtopic.php?f=2&t=593
Re: lambdasonde
Beitragvon TyskeBiler » 1. Apr 2013, 15:44
Hello Again.
in saying I should turn on the plug. What number is RUF?
TyskeBiler
Autos: w201-2.5-16v
Mitglieder in diesem Forum: Google [Bot] und 12 Gäste
