w201 2.5-16V a/c problem
Beitragvon gisek » 28. Mär 2011, 11:51
Hello all of 16V owners.
I`am proud 2.5-16V user and I am looking for any info about a/c system. I have this type (http://img66.exs.cx/img66/8997/w201_euro_klima.gif on the right). Problem is that, it doesn`t work. I would like to check what causes problem, but i did not find a proper diagram (etc.) that shows position of a/c parts in engine compartment. Especially I `am interested in posistion of these parts:
- a/c compressor pressure switch
- refrigerant pressure switch.
Recently I had to fix a/c compressor socket because it was almost smashed. Socket is just fine know, but still a/c does not work. Maybe You can help me?
gisek
Autos: W201 2.5-16V
Re: w201 2.5-16V a/c problem
Beitragvon ilp » 28. Mär 2011, 13:45
Hello Gisek,
I think I've got what your're looking for.
I've sent you a PM, look in your Box.
It' s in german, I hope this works for you, if you have problem in translating something, just ask.
If you need anything else, just ask. :-D
And please set a short answer here, when you got it, so I can take it off again.
Ilp
ilp
Beitragvon gisek » 28. Mär 2011, 14:02
Hey ilp, thank You for such quick answer. Maybe I`am blind but i don`t see any link. Can You send it again, please?
gisek
Autos: W201 2.5-16V
Beitragvon ilp » 28. Mär 2011, 16:52
Hello Gisek,
I've sent it per PM, maybe the system didn't let the link through.
Here it is:
http://www.zeitfieber.de/w201/
regards
Ilp
ilp
Beitragvon gisek » 28. Mär 2011, 21:53
ilp hat geschrieben:Hello Gisek,
Here it is:
regards
Ilp
Thank You for file. I really do not understand german so good so I will be pleased if You can help me with it. I would like to understand they way this klima works. It depends on few things, switches also, pressure in klima system etc. As I wrote I fixed socket of klima copressor, KLIMA Relay i think is alright also, know I` am looking for is switch that checks pressure in klima system and magneticswitch of klima compressor. Maybe You will be able explain it?:)
gisek
Autos: W201 2.5-16V
Beitragvon meisterjäger » 28. Mär 2011, 22:47
you have two pressure switches on the "Trocknerpatrone", it´s the thing behind the left front light. one is for the fan switch, and the other for the main pressure.
Beitragvon gisek » 29. Mär 2011, 06:25
And where can I find magnetic switch for klima compressor? It should be somewhere in engine compartment, I`ve looked it in front of engine head (there are four switches there). I will look for these two switches You`ve mentioned and then I`ll think what next. These pressure swithes should have some precise resistance? I will check them with multimeter.
gisek
Autos: W201 2.5-16V
Beitragvon gisek » 3. Apr 2011, 20:51
Meisterjäger hat geschrieben:you have two pressure switches on the "Trocknerpatrone", it´s the thing behind the left front light. one is for the fan switch, and the other for the main pressure.
I`ve checked pressure switch for main pressure (switch turn on the a/c compressor), but i think there`s no voltage in it`s cables. Does anyone know what gives poweer to this switch?
gisek
Autos: W201 2.5-16V
