ASD malfunction
ASD malfunction
Beitragvon gisek » 29. Mär 2011, 08:55
I think I have ASD malfunction in my 16V. I`ve changed ASD light (without taking out dash) because the bulb was burnt. I`ve checked error codes - ASD unit says that everything should be just fine - no errors. Both ASD and triangle turn on when the key is in ignition position, turn off when I start the engine, but If I try to make slides, ASD does not turn on triangle (it should). Has anyone got similar situation? in few days I`am gonna change wheels for summer, I`ll lift it up and then check if it works.
gisek
Autos: W201 2.5-16V
