16v Oil Pump
I tried to do a search but could not find much if
if anything about this.
On the 16v the Oil Pump is a Gear
type Cog pump driven off the Crankshaft.
Is it the 2.5 16v version which has the wider
main Gear Cog does anybody know please ?
Reason I ask is that the wider main oil
pump Cog seems as if its flow rate would
be about 15% more than the narrower
one ?
Narrower one being from a 2.3 16v ?
The twist is that the 'volume' of oil flow is
actually less in the Oil pump recess on the front
cover in which the 'wider' Cog will fit ?
Part Number for the front covers are-
Wider Cog but less volume-
102 015 11 01 [ 2.5 16v ?]
Narrower Cog but more volume -
102 015 08 01 [ 2.3 16v ?]
This one also has a greater volume for
the flow of the water pump, in that it
has a deeper recess for greater volume.
All and any help appreciated.
Regards,
The Gorilla.
one ?
Regards,
The Gorilla.
