Engine cooling fan
Engine cooling fan
Beitragvon fastn'free » 10. Apr 2006, 11:07
1.When has it it start?
I think it has to start when engine temperature reaches ~100C.
2. How does it works?
Is is thermoplate on fan or is it electrified?
fastn'free
Beitragvon Chris Martens » 10. Apr 2006, 18:33
1. fan engages, when cooling temperature is at 100°C
2. it's an magnetic clutch, voltage is switched via the temperature controlled switch at front of the cylinder head
If the clutch doesn't work, try to bridge the switch first, it's a red one at the front of the engine, should have three pins for your model year.
Ignition on, engine off, bridge the plug with two pins, you should hear a click and the fan should lock.
If it doesn't, check the plug for 12V at one of the pins and ground at the other pin.
The clutch of Rosi's fan had a broken wire, just at the magnet.
BTW, you do have a name to address you? I'd love to know it...
good luck,
1989 300TE
1984 2.3-16
Beitragvon fastn'free » 4. Jun 2006, 17:54
fastn'free
Beitragvon Chris Martens » 6. Jun 2006, 11:37
From left to right:
- temp sensor for the engine temp indicator inside
- temp sensor (4 pin) for KE and EZL
- temp switch for the magnetic clutch of the radiator fan
so: the red one at the right.
should have two pins, three wich a/c
regards,
Mitglieder in diesem Forum: Google [Bot] und 78 Gäste
