3stufen Niveau regulierung Ihn bauen, english manual ?
Beitragvon Cloudini » 24. Aug 2019, 12:53
Hello here
I was wondering as i finally found a car to take the niveauregulierung out,
An old 2.3-16v however this car has no ASD, my 2.5-16v(Evo 2 replika) do has ASD,
Can i make this work together ?
And where can i find english information to set and adjust the niveau regulierung to original settings of an Evo 2 ?
I m going to mount all 4 original Evo 2 dampfers !
I will be taking all pictures of how it was mounted so i know how to put it back on my car, but probably some small adjustments should be need to make to set everything in the right order.
Hope to hear from you guys
Kind regards
Wesley
Cloudini
Autos: 190E
Re: 3stufen Niveau regulierung Ihn bauen, english manual ?
Beitragvon LUDE » 25. Aug 2019, 13:15
Die Dämpfer des Evos`s sind nicht die gleichen wie in die der Dämpfer in den 3-Stufen Fahrwerken der anderen 16V`s.
Beitragvon Cloudini » 25. Aug 2019, 13:55
Dear Lude,
Thank you for your reply, correct the dampfers from an Evo are different,
I have 4 dampfers from an original Evo 2, and im going to build in my car an complete set of an 2.3-16v niveau
But instead of using the 2.3-16v dampfers im going to mount the 4x Evo 2 dampfers
Greetings
Wesley
Cloudini
Autos: 190E
Beitragvon LUDE » 26. Aug 2019, 17:05
Do you have more Evo II. parts?
I would sell the Evo II. Suspension, curse it is so difficult to get the right parts if you own an Evo.
So you will have enough Money to buy the Suspension of a normal 2.5 or 2.3-16.
Curse your car will only be a lookalike not a real one.
But be sure I don't want to say your car is bad or something, I think you will have a very nice car!
Lude
Beitragvon Cloudini » 24. Sep 2019, 21:09
Anyone who can explain me in english how to :
*how to install the ASD to a non ASD competible 3 level niveauregulierung system (entire system took out an “86 2.3-16v with no asd)
*how to bleed the entire system. ( also the shocks are empty of oil )
*how to make sure everything is in the right setup of height and position,
Kind regards
Wesley
Cloudini
Autos: 190E
