Exhaust valves
Exhaust valves
Beitragvon Racing » 17. Jan 2007, 20:47
I´ve previously told you guys about the alternatives when it comes to exhaust valves.
Well,today i took pictures of the different valves and i´ll be posting them shortly.
Also hope to be able to turn some home made guides out of special "lagerbrons" called JM3 to take pics of so you´ll get a better idea of the concept.
Racing
Beitragvon Racing » 17. Jan 2007, 21:27
Forgot.
The exhaust valves i´m going to run in the turbo motor are from an american manufacturer named Ferrea.
Let´s just say...that in general i don´t hold americans and quality in the same sentence,but...when it comes to valves Ferrea and DelWest are good quality valves by any standard.
Just got a call that the valves are here,so i´ll be picking them up shortly and take a couple of pictures of those as well.
One thing´s for certain...i have no idea how mercedes can charge what they do for the crappy-by racing standards-exhaust valves.
Ferrea and DelWest both can also deliver good quality titanium valves for those so inclined.
Ferrea
Racing
Beitragvon Maki » 18. Jan 2007, 00:23
Wenn ich das jetzt alles so richtig interpretiere,
dann könnte jemand der z.B. vor einer Motorüberholung steht, sich die "Alternativen" Ventile und Kolben holen.
So würde eine Revision deutlich billiger werden und man hätte mind. genau so gute wenn nicht sogar bessere Komponenten verbaut !
Oder ist da ein Denkfehler bei mir drin ?
Beitragvon Racing » 18. Jan 2007, 00:42
Yes,you´re correct Maki.
The point is that within reason there´s a given freedome here.
Ie;with a little work(read-modification) there´s a lot to be saved-or for that matter improved if need be.
Zuletzt geändert von Racing am 21. Jan 2007, 11:39, insgesamt 1-mal geändert.
Racing
Beitragvon Racing » 18. Jan 2007, 00:47
From left to right...
1/A stainless steel aftermarket valve.7mm spindle and recut to 33mm at the head.
2/The mentioned Peugeot valve.
Again cut to 33mm head on a 7mm spindle.
3/Stock 102.983 exhaust valve.
33mm head on a 8mm spindle.Sodium filled spindle to cope with the heat.
Point here is that the progress in metalurgy has given that we don´t "need" the sodium anymore-which in turn only makes the valves more expensive.
Further if you take a look at this poor quality picture;
...you can see that the stock valve is a 2 piece design that´s friction welded together.Again...something that we don´t want in a high reving performance motor.
Furthermore the stock valve is made out of a VERY soft material.
Reasons for that....is beyond me at this point.
The stainless aftermarket valve is tough as a diamond.
Racing
Beitragvon Maki » 18. Jan 2007, 00:55
Danke für Infos und Bilder!
:thumbright:
Beitragvon Racing » 18. Jan 2007, 01:12
Thanx Maki.
Stainless steel aftermarket valve.
Peugeot valve.
Racing
Beitragvon Nagilum » 18. Jan 2007, 03:37
Auch wenn ich vor keiner Revision stehe, interessant.
Macht sich der dünnere Ventilschaft auch Leichstungstechnisch bemerkbar?
(Bei NICHT-Turbofahrzeugen) ;)
Immerhin wären das 8x 1mm weniger im Durchmesser.
Beitragvon Racing » 18. Jan 2007, 12:40
I would be hard pressed to say that the thinner spindled valves would improve horsepower per se as the cosworth head flows like nothing you would imagine already as it is,but...
The thinner valves WILL be lighter which WILL leave you more "room" when at high revs,which WILL reduce stress on components.
Like i state the 1mm thinner shaft will not reduce strength in any noticable manner due to evolution in metalurgy.
For the sake of reference NO high performance motors are made with 8mm spindles these days,and the fact is that most work with 6mm.
So..;)
These valves are indeed lighter,will reduce stress,a LOT cheaper and so forth..
Racing
