AMG Power Pack Cams / 11.2mm
Beitragvon Gorilla » 4. Jul 2011, 14:00
Will the std 2.5 16v Dual Valve springs
work OK with the AMG/Power Pack
11.2mm lift cams please ?
I checked the measurements and tolerances and
it seems they are just in spec ?
Regards,
The Gorilla.
Gorilla
Autos: Mercedes 190 16v
Re: AMG Power Pack Cams / 11.2mm
Beitragvon Gorilla » 5. Jul 2011, 12:10
Anybody able to confirm this please ?
Many thanks,
Regards,
The Gorilla.
Gorilla
Beitragvon Nagilum » 5. Jul 2011, 12:47
As the Evo AFAIK needs other (stronger) springs, I think the PP-Cams also won't work with the stock springs.
Also remember that they have a greater basic-circle (I hope you know what I mean, I didn't find an exact translation).
Beitragvon Henger » 5. Jul 2011, 13:03
Hi Gorilla,
the AMG Power Pack intake camshaft lift 11.6mm
Beitragvon Gorilla » 5. Jul 2011, 14:41
Thank you for the replies.
Are we sure on 11.6mm ?
I am getting 11.2mm when checking/measuring ?
They are PP cams. I have here.
11.6m would need springs as 11.2 is right on
the limit for std 2.5 16v dual springs.
Valve cut outs on pistons was done for
12mm lift with 11.5.1 C/R, and larger diam
also cut for combustion shear.
Many thanks,
Regards,
The Gorilla.
Gorilla
Beitragvon Dr.Benz » 6. Jul 2011, 22:36
Hello,
just have a look at the recomendations of www.dbilas.de
Here you find for all (sport)cams with 9,5-12,5mm lift two different (stronger) springs sets
(under products)
Greetings from cologne
Stefan
Dr.Benz
Autos: 300SEL 3.5 , 280SE 4.5, 350SL, 190E 2.3-16, R129, A124 und S124
