Searching for -2.5 16v ''96mm'' Pistons
Beitragvon Gorilla » 11. Mär 2013, 13:52
I am trying to locate a set of 2.5 16v Pistons
at 1st Repair size, 96.00 mm, with a C/H of
34.25mm or higher.
Used or New ?
Anybody able to assist please ?
Many thanks,
Regards,
The Gorilla.
Gorilla
Autos: Mercedes 190 16v
Re: Searching for -2.5 16v ''96mm'' Pistons
Beitragvon ausmNorden » 11. Mär 2013, 14:52
Hi Gorilla,
i´ve got one set of pistons left from my engine rebuilt.
Maybe these are the original ones with 95,5mm diameter, but i´m not really sure about it.
If you are interested, then I will measure them and tell you the facts via PN.
Greetings,
Stephan
Gorilla hat geschrieben:Hi,
34.25mm or higher.
Used or New ?
Many thanks,
Regards,
The Gorilla.
ausmNorden
Beitragvon Gorilla » 11. Mär 2013, 15:47
Many thanks for the reply.
Yes, I require 96mm as I already
have a set of the std 95.5mm ones.
Please let me know what you have.
Many thanks,
Regards,
The Gorilla.
Gorilla
Beitragvon philippww » 13. Mär 2013, 14:40
Hallo!
Ich habe noch die Orginalen 96,00 Mahle Kolben NEU
philippww
Autos: W201 16V , W203 T , MAN c40a , DAX, KTM 250 SX 2t , 2Zyl Rasentrecker auf der Rennstrecke ;-) S123 TD 300 Turbodiesel, Sprinter 270cdi
Beitragvon Christian » 13. Mär 2013, 20:24
Hello!
In Ebay you can find these pistons. I don´t know if the price is okay.
Beitragvon Gorilla » 15. Mär 2013, 20:02
PhillipWW- Danke fur das info.
Sinden 'PM' mit pries und info, bitte.
Sprechan English, bitte /
Danke.
Christian-many thanks for the Link,
those Pistons are for ''Turbo/FI'' motor
as they are only 34.01 CR.
But many thanks.
Regards,
The Gorilla.
Gorilla
Beitragvon ausmNorden » 15. Mär 2013, 22:32
Hello Gorilla,
just to finalize our conversation:
my pistons are the ones with 95,5 mm diameter,
so I think they are not interesting for you?!
Greetings,
Stephan
ausmNorden hat geschrieben:Hi Gorilla,
Greetings,
Stephan
34.25mm or higher.
Used or New ?
Many thanks,
Regards,
The Gorilla.
ausmNorden
Beitragvon sundqvist » 25. Mär 2013, 04:28
http://www.stenparnermotor.se/ send an email to him and he will help you.
sundqvist
Beitragvon qp230 » 25. Mär 2013, 17:55
@Christian
die gibt´s aber schon deutlich günstiger.
außerdem kommen bei den kolben distanzringe zwischen kolben und pleuel meine ich zu wissen...glauben.....gelesen zu haben.
qp
qp230
Autos: c124
Beitragvon Gorilla » 26. Mär 2013, 23:46
Sundqvist- many thanks for the link.
E.mail sent.
Regards,
The Gorilla.
Gorilla
Mitglieder in diesem Forum: Google [Bot] und 81 Gäste
