2.3 & 2.5 16v Parts F/S.
Beitragvon Gorilla » 14. Aug 2017, 12:43
2.3 / 2.5 16v Parts for Sale-
Need to clear these parts as some
changes are on the horizon.
Have the following parts for sale-
2.3 16v Head bare very good condition,
all the valve guides are tight, CC are
good, good valve seats etc- 275.00
2.3 16v Exhaust manifold [RHD], has been welded
not the best but make a good spare- 50.00
2.5 16v 87.2 mm Crankshafts x 2
Both in very good condition, original Journal
sizes, no marks were removed from
92,000 and 97,000 mile engines- 275.00
2.5 16v 9.7Cr. set of Conrods and Pistons all in
good condition [149mm Rods and 95.5mm pistons]- 175.00
2.5 16v set of Conrods [149mm] all in good condition - 150.00
2.5 16v Pair of Camshafts good condition removed
from a 81,000 mile head - 275.00
2.5 16v ABS ECU came off above engine
always kept in dry storage - 30.00
2.5 16v [RHD] Exhaust manifold in good
condition, no cracks or weld - 130.00
2.5 16v Bare Intake manifold in very good
condition- 95.00
ASD Diff x 1 off 2.5 16v useable but would
need rebuild shortly - 125.00
For Pic please PM an e.mail address.
All parts in the UK so are plus shipping
or postage costs.
Many thanks,
Regards,
The Gorilla.
Gorilla
Autos: Mercedes 190 16v
Re: 2.3 & 2.5 16v Parts F/S.
Beitragvon Cloudini » 15. Aug 2017, 00:29
Also got a 2.5-16v front end exhaust with catalyst ? Or just the catalyst ?
Greetings
Cloudini
Autos: 190E
Beitragvon Gorilla » 15. Aug 2017, 09:52
Many thanks for your interest.
Only the 2 exhaust Manifolds, no exhaust parts.
Regards,
The Gorilla.
Gorilla
Beitragvon Conley » 15. Aug 2017, 17:16
Pn.
Greeting michael
Conley
Autos: 4x2,5 16V,2xEvo1
1x2,3 16v Ece
2xAzzurro,
3xw124T
Beitragvon Gorilla » 15. Aug 2017, 20:06
Quote - ''Pn. Greeting michael''
Replied, Danke.
Regards,
The Gorilla.
Gorilla
Beitragvon Gorilla » 15. Aug 2017, 23:01
Seems that members here are very very concerned about the
cost of Shipping, more so for the Crankshafts from the
Island to the Mainland.
Therefore as the Shipping price seems to have raised
concerns for some members rest assured that that all
shipping quotes are from a European Courier based
on the mainland and had the services of a Shipping
Agent based in the UK been obtained then they would
have been significantly more than the prices quoted
to all those concerned more about the actual shipping,
than say the condition of the Crankshafts which in
the circumstances is very very peculiar and most odd.
But if some of those members who have registered their interest
in some of the parts are more concerned about the costs
of Shipping than the condition of the parts, then so be it.
But there are 2 very good 2.5 16v Crankshafts both on original
standard Journals with no marks and should any body really
be interested then please make contact but all this nonsense
of asking for shipping costs before any serious questions about the
parts is seen for what its is.
All genuine enquiries only please.
Many thanks.
Regards,
The Gorilla.
Gorilla
Beitragvon Gorilla » 25. Aug 2017, 16:14
Updated List -
Parts for sale-
92,000 and 97,000 mile engines- 275.00 each
from a 81,000 mile head - SOLD
always kept in dry storage - SOLD
condition- 95.00
need rebuild shortly - SOLD
For Pictures please PM an e.mail address.
or postage costs.
Many thanks,
Regards,
The Gorilla.
Gorilla
Beitragvon Gorilla » 6. Sep 2017, 12:36
Updated List -
Parts for sale-
92,000 and 97,000 mile engines- SOLD
good condition [149mm Rods and 95.5mm pistons]- SOLD
condition- 95.00
or postage costs.
Many thanks,
Regards,
The Gorilla.
Gorilla
Beitragvon Gorilla » 2. Nov 2017, 16:23
Testing to see if they would be any Interest.
I am thinking of changing my Engine and Gearbox
But would like to keep the Car due to all the work
that has gone into it to suspension, steering etc..
The specs are ---
2.5 16v engine converted to single row Chain.
Engine is converted to semi dry reversed Sump
with Direct Oil pick up, so that the sump
pan can be easily and quickly removed, but it can be easily
converted back to a std 2.5 front mounted sump
but retain the direct oil pick up to the Oil Pump.
I run a Manual Quick ratio steering Rack, No Box,
so the sump has to be at the rear]
Block is Bored to 96mm running 11.75 Cr Pistons with
lite Cadmium Wrist Pins [half the weight of 2.5 ones]
and using Pankl 157.4mm EDM rods and Pankl Rod Bolts.
[Pankl Rods are 495 grms with bolts]
Crank is 80.25mm hardened and complete bottom
end was blue printed and balanced to within 0.5 grm.
Uprated bearings have been used in both the B/E and mains.
Head has Intake ports Ported out to 32mm and funnelled
with std size valves running uprated dual valve springs
with lightly ported and polished exhausts, cut back,
to match genuine B&H 4-1 DTM Header.
Intake is BMW S54 50mm ITB's converted and matched to
Mercedes 2.5 intake with the BMW airbox trumpets fitted
into a BTCC race car carbon airbox.
Cams are 11.6mm lift optimised.
Engine runs at 5.25 Bar fuel pressure.
Also runs Coil on Plug using the VW Beru coil packs.
ECU/ DME is a Canems fully mappable which is
like VEMS, DTA 40, etc. and comes with all the Firmware
the CD discs and PC with the maps all loaded etc.
It can be live mapped has storage for 3 maps which can
be changed on the fly.
Gearbox is a 6 Speed from a W203 300 diesel and
gives nice close ratios from 2nd to 5th with 6th
acting like a motorway Gear.
In that it has the hydraulic centre bearing with
the shorter throw changes are short an crisp.
G/Box is rated to 400nm.
Std 16v Flywheel has been lightened by 4 kgs and
a uprated Clutch Ceramic Disc is fitted to a std
16v Cover plate.
[will included the front half of the propshaft as the
W203 G/Box runs a very large gearbox output flange
and much larger Rubber guibio.]
This would all then fit onto a std 16v rear.
Diff not included is a 3.07 LSD but a 2.9 maybe
better if used as a road car etc.
Would also include the complete stainless steel custom exhaust
system which is single 75mm pipe running dual
silencers and is fitted with the 02 sensor for the
ECU set back so as to obtain a more consistent O2
reading as the gases are a little cooler further back.
Engine since rebuild has completed just under a
1000 miles and makes a conservative 270 BHP.
Would be looking for around 8500.00 for the complete
set up etc.
Reason for selling, even though it has been quite a
mission to complete, now its done it not quite
where I wanted to be, so seeing if there is any
interest etc.
Many thanks,
Regards,
The Gorilla.
Gorilla
Mitglieder in diesem Forum: Bing [Bot] und 74 Gäste
