EZL ohne Kat
EZL ohne Kat
Beitragvon TyskeBiler » 5. Apr 2013, 19:46
hello.
Anybody know where I can buy
Abgleichstecker KE ohne Kat: Mercedes Part Nr. 014 545 70 28
Abgleichstecker EZL ohne Kat: Mercedes Part Nr. 015 545 27 28 ........`?
Mercedes has them no longer
Regards Aaron
TyskeBiler
Autos: w201-2.5-16v
Re: EZL ohne Kat
Beitragvon magic2316 » 5. Apr 2013, 21:02
Hallo ich habe den Abgleichstecker mit der Teilenummer 014 545 70 28.
Bei Interesse bitte PN
magic2316
Autos: A-klasse, Sharan, 190E2.3-16
Re: EZL ohne Kat
Beitragvon shaq » 5. Apr 2013, 21:14
Abgleich stecker is just pack of different resistors for each position, go buy 1/4 watt resistor in nearest electronic shop price is ca 0,05€ for each of them, here is which values you need for which position, the most you will need EZL position nr1 that is infinity resistance, thats for EZL its Abgleichstecker is behind ABS pump and for values of resistance inside EZL RÜF Abgleichstecker it is the same as KAT one only positions are differently numbered (only for S and N) so just move EZL Stecker that you slready have from position 4 (s for KAT) to position 1 (s for RUF) for the most ignition advance (means more power, too). In position 1 in both AS there is nothing inside (infinity resistance) all other are the same.
For KE you need to remove KAT Abgleichstecker and in its position (there is two contacts to be seen after removal) near battery resistance of 51 ohms and your ECU is in RÜF programm nr 1 (the standard one). Be sure that inserted Resistor has good contact with its nest.
Here table of values Program No. KAT vs RÜF
Program No:......................How is it activated (with which Resistor):
1.................953 Ohms (KAT) versus 51 Ohms (RuF)
2................1270 Ohms (KAT) versus 105 Ohms (RuF)
3................1620 Ohms (KAT) versus 169 Ohms (RuF)
4................2260 Ohms (KAT) versus 249 Ohms (RuF)
5................3320 Ohms (KAT) versus 348 Ohms (RuF)
6................5360 Ohms (KAT) versus 442 Ohms (RuF)
7...............13500 Ohms (KAT) versus 590 Ohms (RuF)
Regards,
PS Forumkollege hat Angebot gepostet weil Ich dieser Post schrieb @y
Re: EZL ohne Kat
Beitragvon TyskeBiler » 5. Apr 2013, 22:09
Hello.
I'm interested to buy it ....
How we do it
AAron
magic2316 hat geschrieben:Hallo ich habe den Abgleichstecker mit der Teilenummer 014 545 70 28.
TyskeBiler
Autos: w201-2.5-16v
Re: EZL ohne Kat
Beitragvon TyskeBiler » 5. Apr 2013, 22:26
Hello shaq.
I bought my car in germany.
The car has a catalytic converter. according Mercedes is born without catalyst
When I look on the Mercedes program. has the 204 HP
engine code 102,990
I remove the catalyst and oxygen sensor.
I would like to put it back to the RUF.
buy the plug. it is easy????????????
AAron
shaq hat geschrieben:Abgleich stecker is just pack of different resistors for each position, go buy 1/4 watt resistor in nearest electronic shop price is ca 0,05€ for each of them, here is which values you need for which position, the most you will need EZL position nr1 that is infinity resistance, thats for EZL its Abgleichstecker is behind ABS pump and for values of resistance inside EZL RÜF Abgleichstecker it is the same as KAT one only positions are differently numbered (only for S and N) so just move EZL Stecker that you slready have from position 4 (s for KAT) to position 1 (s for RUF) for the most ignition advance (means more power, too). In position 1 in both AS there is nothing inside (infinity resistance) all other are the same.
Regards,
TyskeBiler
Autos: w201-2.5-16v
Re: EZL ohne Kat
Beitragvon shaq » 5. Apr 2013, 22:50
I did the same with mine, the biggest problem was to find front silencer without cat, to cut or empty cat is nonsence don't do it you will lose power, find RUF front silencer
Re: EZL ohne Kat
Beitragvon TyskeBiler » 6. Apr 2013, 01:35
Hello shaq.
I want to make silencer. tomorrow.
I want to use this product
what have you done to your car? as
which number you have turned your EZL ohne Kat and your KE ohne Cat? 1 2 3 4 5 6 7?
AAron
shaq hat geschrieben:I did the same with mine, the biggest problem was to find front silencer without cat, to cut or empty cat is nonsence don't do it you will lose power, find RUF front silencer
TyskeBiler
Autos: w201-2.5-16v
Re: EZL ohne Kat
Beitragvon shaq » 31. Mai 2013, 10:00
"Hersteller Eberspächer Neunkirchen..."
I bought my 2.5 RüF Exhaust from 16v Thomas here in Forum back in 2008. It is original RÜF 150kW front silencer made by Eberspächer, is extreme hard to find was looking for it for a very long time. I have 2.5-16, my EZL is from 2.3-16 ECE 1985 (more power with it) and on position 1 and my KE is now german version 2.5-16 also on RÜF position 1. Position 6 in KE is also good for those who have problems with accelaration (not enough fuel) as it changes map in chip and works totally different programme with it during acceleration phases. It is much better solution than (backyard trick) turning screw inside fuel valve 8)
His car is now sold, but before that as this exhaust was still on the car it experienced a lot of full throttle high speed driving as he was spending a lot of his free weekends on race track.
My car is reimport Swiss and Firmware for injection in KE for Swiss market is in few points different programmed (acceleration is a bit chocked) comparing to 2.5-16 or EVO1 for other countries in Europe (ECE) so I put Chip inside with programm for 2.5-16 for ECE Countries. This ECE has nothing to do with 2.3-16 ECE just the same name noting "for sale inside europe only". I also have chips for EVO2 and 3.2 AMG Originals from Mercedes but never tried them on my car, by checking their firmware out, it seems that they have whole different set of instructions comparing to 16vs. The same way 3.2 amg firmware is different comparing to standard 3.0 or 2.6 firmware :roll: as EVO2 is comparing to all others 16vs and EVO2 cannot be called into RÜF mode it works only in KAT mode but is faster and has broader rev. range.
