jeandersson hat geschrieben:Suppose it should be possible. Is there someone who have tried?I hope my problems shall be over now so that I can just forget about the differential
Did you rebuild and adjust your new differential?
dbr hat geschrieben:jeandersson hat geschrieben:Suppose it should be possible. Is there someone who have tried?I hope my problems shall be over now so that I can just forget about the differential
 a friend of mine is interested in the topic. he got no contact person and the turbobandit converters are pretty expensive
nightXmare hat geschrieben:Hello Hello
I'm Max from the eastern part of Germany.
your one of the biggest reasons why to get registrated at the forum.
I am more in the Diesel scene wich is also verry common in the scandinavian car culture but love the way you build the engine!
The swap to the 210mm asd diff is my next step in rebuildung my whole rear end. I'll use some lasercut Sheet metal and welding work to get the Plate done.
What driveshafts and stuff you want to use? e34 m5 Shafts and Hubs are an option but MB parts and custom shafts are more interisting for me.
Do you lock the Diff with a Handpump?
Where you get the high stall converter from?a friend of mine is interested in the topic. he got no contact person and the tb converters are pretty expensive
sorry for my bad english
mint build!
VG Max
f1jfs hat geschrieben:beautifull car and an enormous amount of work hope it all works well for you.
 )nightXmare hat geschrieben:Thank you for for your fast answer.
Did you thought about compressed air e.g. from your climate compressor to spool the turbine wheel up and create boost pressure where your exhaust gasses are enabled to spool the turbine?
Max R.(the friend with interest in the high stall converter) thought about that too...Volvo used that in some models ...it is common in the off-road scene as well
Did you already some runs with the welded shafts?
I'll try to get my hands on some billet custom ones (my personal favorite is a weldfree shaft)
Greetings Max
Nagilum hat geschrieben:Just go on, also minor things may be interesting (as: what are you showing there? Can't recognize it).
Nagilum hat geschrieben:What's the reason for 140 AMP? We never changed that...
Just to recharge battery faster because you're often starting the engine without having longer runtimes in between?
