Cutting the chain I think is easy in the worst case with a grinding machine …even if horrible only to say ….
I have at home the parts but now I can just post the pictures from internet but is the same
Thanks to address me
Best
Marco
so I took my chain to Germany to Mercedes to have it properly mounted (crazy)
I also found and read the procedure how to proceed, it’s a 10 minute job for someone that do this regularly…or better that was used to do this regularly 30 years ago and more
and don´t believe their design was better.
yes the famous led lights for the service intervals who knows if they are still present in the recent cockpit. But probably long chain layout was very similar also on E30 M3 and their engineers did not repeat the error. I had the M5 E34 many many years ago, I did not go deep as I’m now with our sweet 16
but I remember head gasket blown with nice emulsion of oil in the coolant reservoir.
that's hardcore man, you could easily end with major engine damage. Maybe you were lucky they shifted it the way when piston is in opposite direction from valve, otherwise it would hammer each other and break. That is a big NO for those mechanics.
Mitglieder in diesem Forum: Google [Bot] und 63 Gäste
