Wich oil?
Wich oil?
Beitragvon Medic » 7. Nov 2006, 11:00
Wich oil should i use in evo1 for gearbox and rear diff(lsd), and what is capacity?
Also for "servo lenkung" and how do i change it?
Thanks!
Medic
Beitragvon Chris Martens » 7. Nov 2006, 13:22
hi Andrej,
some recommendations:
- the gearbox needs ATF, take Liqui Moly ATF III, 1.1 liters
- the rear diff needs hypoid oil for LSD, take Castrol SAF-XJ or Liqui Moly SAE 75W-140, 1.1 liters
- the power steering (Servolenkung) needs oil for power steering or any ATF Dextron II will do
There is a filter at the bottom of the power steering reservoir, that has to be changed.
The procedure for oil change is described here:
http://www.sternzeit-107.de/modules.php ... le&sid=228
You should change the hydraulic oil of the SLS and the ASD (it's actuated with the same oil as the SLS) as well, there is a special hydraulic oil available from febi. You'll need at 3 liters to rinse all of the debris from the hydraulic system.
regards,
Beitragvon Medic » 7. Nov 2006, 15:08
Ok, thanks allot!
Medic
Mitglieder in diesem Forum: Bing [Bot] und 116 Gäste
