Getrag
Getrag
Beitragvon Racing » 13. Okt 2006, 18:33
Anyone know how to take the rear housing off of the getrag boxes in our cars?
Got a spare,and thought i´d take it apart to check it up and install new bearings asf.
Racing
Beitragvon Matsalleh76 » 5. Mär 2007, 10:06
Did you ever get the thing open and re-built? My gearbox is worn and a want to rebuild the spare. If you know of a source of info on this box let us know.
Thanks & regards,
bobf.
Matsalleh76
Beitragvon Racing » 5. Mär 2007, 10:32
Yup Matsalleh.
Got the box taken apart alright.Was just a matter of becoming a little violent :D(You get to gorilla it apart)
Box is basicaly built as a race unit really,with separate gears at the bottom held in place by seeger rings.
Racing
Beitragvon Matsalleh76 » 5. Mär 2007, 12:21
Thanks for the prompt reply which of course leads to additional questions:
--Any info on tolerances?
--Switching from ball to tapered roller bearings?
--Re-bushing forks or shift levers (the levers on the outside of the box)?
--Lightening gears (VERY VERY successful on an Alfa box)?
--Wear points to be watch for?
The lack of info on these gearboxes is surprising.........
Thanks & regards,
bobf.
Matsalleh76
Beitragvon Johan.c » 5. Mär 2007, 20:27
Please Matsalleh, leave the getrag original!
Getrag have done some seriously testing on this gearbox!
The getrag should sertenely hold more then cars life...
Original Parts is a good word regarding this gearbox.
Johan.c
Autos: 2,5-16 1992
320e 1993
Beitragvon Racing » 5. Mär 2007, 23:19
In essence i´d say that Johan is right.
When it comes to tolerances,wring out the textbook.
No need to swap bearing type.
Check bottom stock bearings for outer race failure or wear.
If you wanna attack anything within the box i for one would put the sliders in the lathe to lighten them.The Getrags are fairly "slow" shifters as is.
Racing
