16v Parts for Sale
16v Parts for Sale
Beitragvon Gorilla » 10. Mai 2012, 13:14
Now that my 16v project is nearly complete
I am looking to sell those parts on which
are not part of the Spec/Build of the car.
Here is a link to the parts for sale
and the asking prices.
All parts are in the UK and pictures can
be supplied upon request.
http://190rev.net/forums/showthread.php?t=41636
If interested in any of the Parts then please
contact via the Thread or Forum PM.
Many Thanks,
The Gorilla.
Gorilla
Autos: Mercedes 190 16v
Re: 16v Parts for Sale
Beitragvon Gorilla » 10. Mai 2012, 15:42
Here is the List of 16v Parts.
For Sale-
1/
1 x 2.5 16v Crank in very good condition,
all std size Journals, all very good, was all
checked and Polished, and then not used.
Engine had done 73,000 miles [confirmed]
Looking for 395.00 ono
2/
1 x 2.5 16v bare Block, will require a Rebore
to 96.00mm as there is some small pitting to
bores that are visable after it was 'honed'.
Looking for 325.00 ono
3/
I set of std used 95.5mm 9.7 CR 2.5 16v
pistons and pins.
Good overall condition.
Looking for 75.00 o.n.o.
4/
1 X 2.3 16v Complete head with Cams
Valves etc.
Could do with stripping down, purcased as
part of a tall engine as I only needed the
engine Block.
5/
1 Pair of 2.3 16v Cams, in good condition
are bare cams no sprockets.
Looking for 100.00 ono
6/
1 x 2.5 16v Alloy Intake Manifold good
condition, larger diam intakes than a 2.3 16v
would be good for 2.3 16v upgrade or
fabricated for ITB's etc.
Looking for 150.00 ono
7/
2.3 16V Crank, needs regrind to first repair
but is straight and true.
8/
1 x 2.5 16v Engine ECU working in good condition,
was on a 1989 Car.
Looking for 175.00 ono
9/
1 x 16v Sump Pan good condition
will fit 2.3 / 2.5 16v
Looking for 65.00 ono.
10/
I also have a complete running 2.3 16v
engine that runs very well, can be heard
running, still in car and can be test
driven, but does require the chain guides
doing.
Will sell Complete with its 5 speed Getrag Gearbox
which is very good and tight, no rumbles and all
syncros good etc, and all gears etc
including Clutch and flywheel and engine harness
with engine ECU and Ignition etc
Looking for 695.00 ono.
11/
I also have a C36 AMG Large Case LSD Diff
which is the later 3.07 Ratio and the half
shafts to go with it in excellent condition,
purchased to use with C36 Engine swap
but went 4 pot 16v instead, oh dear !!
Car had done 54,000 miles before it
was front ended.
12/
Also have a W124 Large Case Diff with
3.69 CW/p in very good condition.
Looking for 75.00
Many thanks,
Regards,
The Gorilla.
Gorilla
Beitragvon meisterjäger » 10. Mai 2012, 15:59
what is ono ????
Beitragvon Gorilla » 10. Mai 2012, 16:07
ONO stands for ''or near offer''
Hope that helps.
Regards,
The Gorilla.
Gorilla
Mitglieder in diesem Forum: Bing [Bot], Google [Bot] und 4 Gäste
